Tuning turbo
Tuning turbo
okso this kit cost around £1400 how much is a intercoller to keep the temperatures down for this kit?
i really like the sound of this but idealistically id want a techs point of view on running it ona 8v with low boost before i think on splaxhing out
Benefits of STS Remote-Mounted Turbochargers
Lower underhood temperatures. No need to worry about melting wires, hoses, or other engine components, as with a front-mounted turbo.
Ease of installation. STS turbo systems can be installed in about 8 hours with standard tools and average mechanical ability.
Cooler oil to the turbo. Cool oil is better for both the turbo and engine.
Performance Sound. The turbo acts as a muffler and sounds like an aftermarket performance muffler. Turbo spool and rushing air from the blow-off valve make a unique sound that will turn heads!
No need for major modifications to your vehicle. STS systems are designed to "bolt-on" to factory mounts.
Increased gas mileage. Unlike a belt driven supercharger, the turbo utilizes "wasted" energy leaving your tailpipe. Most of our customers get 1-3 mpg increase in gas mileage compared to their original stock mpg numbers.
Converts back to stock in about an hour.
More room under the hood. Future repair work or modifications will not require the expense of removing the turbo system to allow access to engine components.
Lowest Intake Air Temps. Low IAT's equate to more horsepower per pound of boost than any other forced induction option. STS intake piping provides built-in intercooling. Add the optional intercooler, and IAT's drop even further.
Approximately 500F lower turbo temperatures. Eliminates the need for a turbo-timer, which allows the engine to run after the car is shut off in order to cool down the turbo and prevent oil and bearing damage.
Denser exhaust gasses drive the turbo turbine wheel more efficiently.
Turbo is exposed to ambient air rather than underhood air. Allows for better cooling of turbo components.
No need for expensive headers, mufflers, or exhaust systems.
Turbo is closer to the tail pipe outlet. Provides a better pressure differential across the turbine wheel which promotes better flow across turbine.
Better weight transfer. Increases traction because the bulk of system is mounted in rear of vehicle rather than up front.
Less noise and heat in the passenger compartment.
this is what the kit looks like
Overpriced for what you get. £350 turbo plus trinkets. £500 tops as most of it's china produce.
A turbo is "A turbo" no matter where it's put in the exhaust system. The technical issue with placing the turbo away from the engine is...The longer pipe run = more system volumes = increased boost time. The difference between pumping up a truck tyre and a car one. The lag may not be too noticeable as turbo's are quite good at compression or extraction.
With that turbo system, where you want the intercool to be?
ming
i wouldn't bother with one. The turbo is far from the engine so it won't dump as much heat into the charge, also having a length of ally pipe run the length of the car will get rid of heat.
An intercooler is just adding to the weight and making it more of a faff to fit everything.
May as well go outside and chuck various monetry notes into the air!
Spending £1400 on that thing that is probably worth more than rynabooths car, priim3s car et al that have shown an interest in this
I get people like ming, arc et al who build up spends over time on their cars, but i think you would need your head examining to part with that kind of cash on a cento especially when already mentioned there are better ways of turboing these cars for far cheaper
And i bet none of the interested parties in this have even bothered to check what their insurance will be to see if its worth it when declaring it as a mod
seems to me their are a few people dreaming this can be done on the cheap and easily. think again please.
Turbo's down the rear, yes doable but its not going to be any cheaper, and may not even work particularly well. The OP seems to have an spi from the avatar pic. Would make more sense to make up a system more like the tried and tested ones already about. In which case there's alot of people here that can advise on problems as we have all been there already ;) that in the long run will save so much hassle ad faffing and getting angry trying to understand whats not working/gine wrong etc.
Building a kit up similar to the VA high boost isn't really that difficult.
Or the easiest route by far, one chosen by me, buy a turbo cento and make it your own. By far and away the cheapest option ;)
a turbo conversion would only bump my insurance up a extra £100 and a engine swap is just a little more than that id rather go with a conventional turbo and a 1.2 engine swap after thinking about it
