Technical turbo water pipe
leicestershire
hi, does anyone know where i can get the 90 degree water pipe which is on the turbo (union type fitting)i'll try and put pics up tommorow.
its a mk1 by the way :)
cheers
Don't suppose anyone else has one of these pipes - my car is off the road until I can get hold of one.
Does anyone know if some of the newer Fiats with Turbos use this same part? If so, would a dealer be able to supply one still?
Peter
oops - looking at the photo again, I think I need the other ali hose - the one that has 2 bends in it. The hose I need attaches the turbo to the block via a rubber hose. The hose I need is attached to turbo via a union that has a 16mm thread.
Thanks again
Peter
that's the one Mark took - the water hose with two bends.
I can see why they brake.. that short rubber hose is a right pain to fit when in the Uno's engine bay, don't know what the space is like in the Firecat :confused: can only guess same or worse.
would it be on shop4parts.co.uk at all?
Steve- that looks really cool :)
