Technical Turbo injectors.
syrill-sneer
I've had a read around and am I right in thinking that cosworth injectors are a straight swop for the injectors in the mk1 uno turbo, and if so are standard cosworth injectors seen as upgrade?
Cheers, Tim.
Mk1 turbo uses hose tail 280 150 series injectors. I assume Cosworth would also use 280 150 series injectors but not hose tail. So not a direct swap without modification. They would be a swap for a Mk2 turbo. Yes definatly an upgrade.
I found that Opel Commodore from the 70'ies have injectors that physically fit the uno intake. But will need another engine control system, as those injectors are 2.5 ohm instead of the 15 ohm or even more that the stock injectors has..
These commodore injectors flow approx 400cc/min.
Im going to fit a VEMS ecu to my uno
