My Juan and only Uno.
I have an Uno 45, 998cc Fire engine with an Uno turbo speedo clocks. The Speedometer, Gasoline indicator, and tachometer are all working. Engine temp indicator will just function when the engine overheats. As in the old Uno 45 clocks, the red temp light turns on when the engine overheats.
The engine temperature, oil temp and oil pressure are not functioning. Is there any possible way for it to function? If I would get a temperature sensor, also the sensor for the oil temp and pressure will it work? on the fire engine?
Thanks in advance.
Thanks in advance.
