Tuning  Tuning bits
Tuning  Tuning bits
Chrishalecinqi
Does anyone know of short shift kits for a Cinque sporting as I fitted one to my saxo years ago and it made a decent difference. Also anyone know of performance parts for the standard lump, ported polished throttles, cam etc, can't find much for sale thanks
Depends on budget and insurance availability.
C&B do a range of cams, if you go too lumpy you will need a management system change.
There are 40mm TB available, Decent exhaust manifold, cam set properly and you can have a wee firecracker.
If you want serious power, replace the 1108 with the 1368 with its own management and away you go with a whole lot less hassle.
For a mild tune up, 866 cam and 32mm TB is pretty undetectable.
Bear in mind the brakes and suspension will need attention too and the shell would be wanting some added strength.
No issue with insurance just wanting a little play around the, any good companies recommended
