Hi everybody, this is my first ever thread in the Fiat Forum, which I am loving by the way! I hope some of you can be of help to me.
Basically I recently bought a Punto MK2B 2003 model and the standard speakers are not the best, so I want to upgrade these. I have little knowledge on speakers so would appreciate any help that is given. All I would like to have is a system that can be played reasonably loud with little sound quality loss. The standard ones can barely be played on half volume without the sound quality decreasing very noticeably and they don't have as much bass as I would like.
I don't have a lot of money to play around with so I bought a 'Sony CDX-GT26' head unit recently which is 4x45w.
At the moment I'm not worried about a subwoofer because I will be using the boot and need the space. And I'm looking at JBL speakers all around. I'll add the mounting depths as well so you can tell me if they will fit in the existing speakers holes.
I was thinking of buying (I did try put in URL's but it said i wasn't allowed. I found these on the uk dot jbl dot com website):
JBL GTO938 6x9s for the parcel shelf
JBL GTO428 tweeters to obviously replace the standard tweeters
(Mounting Depth - 51mm)
JBL GTO6528 speakers to replace the door speakers
(Mounting Depth - 59mm)
I have just read something about getting component speakers instead of coxial but I still dont really understand the pros and cons and if it would even be worth it for me. If components would be better than buying the door and tweeters separately would these be any good:
JBL GTO6508C
(Mounting Depth - Woofer/Tweeter 59/39mm)
If i do ever get a subwoofer which I probably won't, it would be a cheap one like this:
JBL GTO804
This will be a slow process as I don't have lots of money at a time to spend so which would I be better off upgrading first?
I'm guessing these would need more power than the standard speakers to operate at the higher volumes, but would the head unit power be enough for reasonably loud sound, or do you recommend me getting an AMP? Also this is probably a dumb question but how many AMP's would I need? :doh:
If I did get an AMP it would probably be this one due to lower price:
JBL GT5A604E
(4 Channel)
So would anybody be able to advise me on this subject, if so I would appreciate it so much as I don't want to spend all that money and then be told I should have done this or that and have to shell out more money to change it.
Thanks for reading guys and thanks in advance for any help/suggestions you may have
Ash
JBL GTO6508C
JBL GTO804
JBL GT5A604E
(4 Channel)
Ash
