Technical Trouble finding 'F35' reverse light fuse for reverse camera power
KarlosM2C
Hi All,
I am trying to wire in a reverse camera to my Fiat Ducato Euro 6 2017 panel van (Multijet 115), but I just cannot find the location of fuse number 35, which is listed on multiple diagrams for this vehicle as being the fuse for 'Reversing lights, sevotronic control unit, Water in diesel fuel filter sensor, (+key)'. These sites all acknowledge fuse F35, but in their diagrams it just isn't showing that location. It shows locations for fuses F33, F34 and F36, but NOT F35, which is really odd. Can anyone please help me identify F35's location?
I want to connect in a piggy back fuse in to this F35 fuse so that the reverse camera can switch on when we put the van in reverse. I therefore assume, and please correct me if I am wrong, that there will be no voltage running through this fuse when not in reverse, but then 12 volts or so running through it when you put it in to reverse (?).
Can anyone else also advise where I should connect the ground the negative wire to in this general area?
Any help on this would be much appreciated.
Many thanks,
Karl
**EDIT** I have now seen that there is another fuse for reversing light - F51, which I have located. It would still be good to get some help on the other questions if possible. Thanks
