Let it run up to temp, turn it off, start it again and redline lit 3 times in quick succession, may do the trick.
Kristian
while your neighbours think the Russians are coming
Kristian
why??? it wont make any differance. I take it you have reset the ecu already? (run engine till fan comes on then quickly turn engine off and disconnect battery (before the fan goes off) for 30 or so seconds)Just gotta run her in nice and gentle now ... time to lock the lead foot in the cupboard for a couple of days![]()
To reset the ECU you need to fully discharge a couple of hold-up caps, after pulling power to the ECU this takes somewhere between a handful of seconds and 15min depending on who you believe. So just disconnect the battery for 30min and job done.
thats why the fan thing worksTo reset the ECU you need to fully discharge a couple of hold-up caps, after pulling power to the ECU this takes somewhere between a handful of seconds and 15min depending on who you believe. So just disconnect the battery for 30min and job done.
think your throttle cable is too tight!
How much of a spazz do I feel? Was installing my induction kit, and noticed the idle controller wasn't connected :bang: :doh:
All running sweet now and idling at around 800-900 rpm :slayer:
