top pulling timing belt marks
T
tina
does anyone have a timing belt diagram for the top pully markings please
yea what it is the car starts but then when driven and stopped the car appears to have flat battery new battery put on same prob ? timing belt not lined up properly need to check alignment markings to check belt in correct position
If there are no marks on then marks should have been put on when the belt was removed. you will need locking tools to set the belt correctly.
there is a mark on the lower pully to line up with but there doesn't seem to be one on top pully??? any ideas
Has the car had a new belt on? any lights coming on ,on the dash? Like Tom says timing belt will not affect the battery but a loose connection will affect the engine. So check all connections
K
7
7K
keval
K
K
6K
Keval
K
J
2
448
M
1
644
Dark Lurker
