Hi.
These idle problems drives me nuts:bang: .
First the engine idles like scrap all the time
(To low charging voltage)
Then the idle is low all the time followed by too high Co readings
(Lambda probe)
Now it idles fine at cold start and during warm up, but when engine reaches working temp, the idle speed is below 500 rpm, but steady.
I read some where that the ECU uses coolant temp for setting idle speed during cold start and warm up, when the engine is warm it uses the RPM signal from the TOD sensor.
So in my case it could be a defective TOD sensor, or could it?
The RPM reading on the dashboard is OK, doesn't is use the same sensor?
How does a engine run without the TOD sensor? My guess it would have problems with ignition timing causing missfires.
Any advise would be great, i'm lost in this bad idle problem...
