alexGS said:
I think that most 1372cc engines have a block-mounted distributor, FWIW.
Haynes Service and Repair Manual, Supplement: Revisions and information on later models: Chapter 13, section 7. Nice picture of a 1372cc i.e. engine with camshaft mounted distributor
To make it confusing, I think that some 1372cc engines had a block mounted distributor, and some had them camshaft mounted. Fiat obviously couldn't make up their minds!
alexGS said:
The Tipo gearbox is the same as the Mk2 Uno 1372cc gearbox. That means different linkages to the 1301cc Mk1 Uno.
I forgot about that
Yes, later Uno's had internal rod linkages, whereas all mk1's had external. Not sure if the two can work with either gearbox?
alexGS said:
Incidentally there will be numerous little bits like the thermostat and the heater plumbing that are different between the Uno Mk1 and the Tipo.
The obvious answer here is to put in a Tipo 1580cc engine, using a Mk2 Uno for parts (gearbox, gearchange, driveshafts, cooling system, hydraulic clutch pedal box etc.) At least, that's how I see it.
Yes, using mk2 Uno 1372cc parts it should be a straight swap into a mk1. Is there a lot of differences with the heater plumbing and thermostat between mk1 1.3 and mk2 1.4?
Bill/Uno can't go up to 1580cc as he's restricted to 1400cc in his racing class. But as mentioned, grind the engine capacity off the block and no-one will know
alexGS said:
Otherwise just raise the tune of the 1301cc engine - twin sidedrafts, hot cam etc. I'm not certain of the need for balancing and blueprinting the engine, unless you're aiming for peak power at 9000+ RPM. Chas - have you ever blown up a FIAT engine?
Nope, never blown one up yet
However, balancing/ blue-printing will make a more revvy and smoother engine, plus put less strain on the parts. If the engine is in bits, it's a worthwhile job to do. Might even get 1 or 2 bhp more due to less recirculating weight being moved around
alexGS said:
As far as power goes... I remember a FIAT 128 pictured in catalogues from the 70s that had Kugelfischer mechanical injection. Out of 1116cc, they got 165bhp. I think that proves that capacity is just the beginning...
A well built engine with the right parts can produce quite obscene amounts of power
But here's another suggestion to make a really strong engine. Why not find a 1301cc turbo engine with a blown head, then use the normally aspirated 1301cc head on it? The mk1 turbo apparently had a forged crankshaft and forged connecting rods so is immensley strong. The turbo 1372cc didn't have quite such exotic components so I've heard?
Also, the turbo came with an oil cooler as standard so this would be a help for racing.
Of course, non turbo 1301cc pistons will have to be used else the compression ratio will be too low. A bit or mixing and matching and a very strong and potent 1301cc engine could be built.
alexGS said:
So, not worth changing from 1301cc to 1372cc in my opinion.
Thanks,
-Alex
I agree, there appears to be no benefit at all in going from 1301cc to 1372cc. Going up to 1580cc IS worth it, as without any modifications you'll be getting around 80 - 85 bhp without any tuning work. A bit of tuning and 100bhp would be very easy to achieve, which is not bad at all when you think that a standard mk1 turbo is only 105bhp. Of course, a turbo can be hopped up to produce MUCH more power, but they aren't allowed in Bill's racing series.
I must get that sticker that says 'Fiats Are Faster Than You Think'
Chas
