Lozza123
Hi lady non car savvy driver here ,just wondering what my 500 x tickover should be and is easy to change if wrong ,currently ticks over at 1000 rpm .
Thank you.
Thank you.
Thank you for advice .I will monitor it as you say.1000 at cold is OK I would expect a bit less once warm. Its not easily adjusted as it is controlled by the cars computer. If the temperature gets to normal (mid range) reasonably quickly after starting up,its probably not something to worry about. Car gauges are not very accurate and it may just be a slight over reading. Psycologically seeing 1000 rather than a fraction less is stressful. I suspect there is nothing to worry about. If it sounds like its running around the right speed I would ignore this and just monitor it. It won't affect fuel consumption by any significant amount.
