Technical  throtle body - no power
barnsley
:D so il start from the begging first of all my 1.2 80 sx brava was realy bad on idelling and kept trying to stall all off the time :( so i decided to sort it out anyway of came the pipes to the throttle body and after a quick inspection found out it was discusting inside so i cleaned it out with all of the proper cleaners and that
with the pipes back on i started her up ( the car ) perfect no more loss of revs and runing a lot better now and a bit quiter BUT now the car seems realy slugish :eek: any ideas y it might be doing this could it be anything to do with the throttle body been cleaned :confused: or will it start piking back up getting back to normall but slowley so any help will be so much appreciated thanks:worship: :worship: :worship:
the throttle body often causes problems on the 1.2 when you disconnect it because the throttle position sensor's range needs to be learnt by the ecu. this requires the use of fiat's examiner machine.
