This might be more appropriate for the tech talk forum but...
2014 Panda Pop 1.2 petrol
I have a slow weeping leak at the thermostat as evidenced by crystallised pink antifreeze on the pipe and a very slow drop in the header tank level.
The cam belt and water pump were replaced and new coolant added around 10 months ago.
Q. Do I really need to drain the entire system to replace the thermostat or can I just syphon out via the header tank to get the coolant to a level lower than the thermostat housing in order to swap it out? Any idea how much needs to come out to get to this level?
I'm sure I've done this many years ago on other vehicles. As long as it's properly purged of air after refilling I can't think why this shouldn't be OK.
The new thermostat has a metal pipe stub as opposed to the leaking plastic one on the OEM part.
Thanks.
Thanks.
- Model
- 1.2 POP petrol
- Year
- 2014
- Mileage
- 72000
