Went to flush the system out today and it went wrong right near the end!
Everything was going swimmingly. I ran the hose through and all the yukkie stuff came out til the water was clear. I had purchased a new thermostat to save the agro of having to clean up the new one.
The place where I bought the thermostat told me that it didnt come with a paper gasket and so they persuaded me to buy a liquid gasket.
I did as it said, put the stuff around the mating face of the thermostat and then bolted it to the engine block. I waited just over an hour for it to set and then I went to run a rad flush through the system to try and get rid of anymore grime.
I couldnt believe what happened next!? The water and rad flush started bubbling through the side of the thermostat where it fits against the engine block! It musnt have sealed properly :bang:
I turned the engine off and then tried to turn the bolt head (front one from bumper) to tighten it a bit more incase that was maybe the case. It turned a bit more and then
the bolt head just snapped right off!
The bolt is now kind of way stuck a bit inside the hole of the thermostat and the rest of it in the hole where it goes on into the engine block! Even more water was coming out when I tried the engine on again!!! Nightmare! And yes, I know, its friday the 13th! lol
Anyway sorry for the big long story. Does anbody know away of getting the thermostat of now?
Any good tips!?
Any good tips!?
