TheFlyingFiat1986
Hello, I am a new member, I have a Punto HGT 1.9 diesel, the caliper is bigger than the normal Punto which is 284 mm disc. Recently I had a both front new caliper piston rubber seal which I fit myself with special grease for brake piston lubricant.
Afterwards fit new EBC Green stuff pads with new disc (normal disc no grooves or drilled) and I have pumped the pedal, so the piston is fully close together between the pads, when I have tried to spin the disc it feels not free spin but a bit stiff, is this normal with new pads?
Do you reckon the piston inner new rubber ring need to get in using to become smooth?
