Technical  Temperature knob jam
cyberbird
Ljubljana
Hi, I need help.
Temperature control knob jams/sticks around the middle. I opened bottom panel, removed cable gear, tested and determined cable works ok, but that primary gear for internal shaft is jamming. I had troubles rotating it with fingers, had to use combination of cable and fingers to jiggle it to unstuck it just enough to switch to cold air for this summer.
Can I even do something to "lube it" or fix it without removing whole dashboard? Any advice would be welcome.
Model
Doblo
Year
2017
Mileage
80000
