depends what engine you have.
if its the 1.4 then its tapping because the head isn't getting enough oil curculation so the hydraulic tappets aren't getting enough oil to correctly adjust the valve clearances. the excess gap allows a tap as the rocker strikes the valve.
to solve it you can use 2 cans of engine flush, have it running for half an hour with the flush in, then drain it and use fully synthetic 10w40 oil, castrol is my 1st choice. dont forget to change the oil filter before adding new oil.
if it still taps after that you'll need to remove the sump and clean inside the oil pick up pipe, then remove the oil flinger bar from the head and give it a good clean.
