Hi guys, I'm new here and hope somebody can help me out here as quite a few have done this job already.
so I got now a new VL36 and want to swap is asap.
Unfortunately I didn't get any new seals with it.
Regarding the swap I hope somebody can give me a tip, what the easiest way is. I could do a manual for this forum if it works out well. I see 3 options but I bet one is wrong:
1. Change the whole turbo, so taking all coolant pipes off, 4 bolts underneath the turbo and 4 nuts to the cat pipe. That would require new gaskets all round right?
2. Changing only cold side. So you take the bolts off that hold the aluminium compressor housing in place (marked in yellow in the picture). Actuator would be loose, but could stay in, right? What about the compressor wheel? Do I change that, and how? In this case I wouldn't need new seals, as the hot side stays in.
3. Unbolt the V clamp in the middle of the turbo (marked in green), so change the compressor housing/wheel and the cooling centre part. Now I don't think that is what I should do, but I don't know.
(not my picture btw, found on google)
As you can see I try to find the easiest/quickest/safest way of doing the job. The car has been really good to me, especially on the Nürburgring, and I want to keep it that way.
