did i quick search but couldnt find anything with v8 in it. i remeber reading a thread about a bloke that done a build like this on here, he had the exhausts at the front but cant find it now, this looks a little like his.
An eaton in Punto has been done by davethetrike. It went bang, but what the hell. 16 valve engine, so when the crank pulley sheared its keyway the engine ate itself.
Like I say, I can't see an Eaton fitting a Cinq for space reasons. But I'm pretty sure a Rotrax centrifugal blower can be squeezed in.
perhaps some kind of drive from the flywheel end, but that may be difficult as well.
It just created a whole new list of 'things to do', it came out of the left field for meYes,the lot went on ebay a few months back, so all that had it on your list of 'things to do' you missed your chance.
@brooky - yeah, its that easy lol why didn't i think of it. The gearing will be totally wrong, you'll need to cut the geabox casing, make some mounts, and get the tolerance just right.
@cc1 - that was a plan on the 1.4, but the whole AC mounting had to be junked, as it used the sei engine mounts point lol.
O
n the 1.1 though i'm sure it could be done with the ac mount. Only concern, even on the AC version, the belt is still only a 5V, no where near the rotex 7V/8V. Not sure is it due to additional load or what though.
Kristian
the Rotrex doesn't usually need an oil cooler.
