J
Joske
Basically i found a wet patch appear on the drivers side in the top corner, normally where the ultrasonics of a car alarm go.
Ok i took the roof lining out so i can find the leak. I poured water over the sunroof and i sat inside the car watched for drips. After a while a small drip apppeared from what looked like the corner of the sunroof unit, theres also a pilot hole further up and its leaking from there.
The leak doesn't come from the drainage hole as its not blocked, so i opened the sunroof and poured water into the gutter on the drivers side and the water rushed round and drained off, however because of the flow of water was continuous, it started to leak from these points quite quickly, fast drips. I have replaced the sunroof seal about 8 months ago so it cant be that.
I really am stumped for ideas, it doesn't over flow because water would drip from a certain point on the sunroof, so any ideas and suggestions would be great.
Thanks Joske
Thanks Joske
