Technical  stud pattern info required
burstnerboy
hi all
ive just bought a 2003 fiat ducato motorhome its a burstner 747 based on the ducato 2.8jtd with the 5 tonne chassis my question is . is the stud pattern on this model the same as the new model as im looking for wheel trims and ive found ones for the new model but not sure if theyl fit as they are secured through the studs cheers for any info
Hi yes stud pattern is different had to fit valve extentions on mine , but need to be the metal ones, as my tyre pressure is 80 psi hope this helps.
