Besides marginally easier mounting what are the advantages to wheel studs n' nuts over bolts?...
rallycinq said:Much easier to change in the dark, as was siad above.
kritip said:I have had a look about but can't figure out exactly what they are lol![]()
They are bolts that screw into the wheel hub, and then stick out, then a nut goes on top of them??
kritip said:Can they only be used if you fit spacers?
kritip said:What stops the bolts coming loose if how i think they work is correct??
kritip said:Cheers,
Kristian
Oh another userallycinq said:I use a selection of wheels for different surfaces, they all have different widths so I use spacers sometimes. Using the stud conversion means I can use the same nuts with any wheels.If I was using bolts I would need a selection of them of different lengths.
