Technical Stuck in gear ?
Bengo
Hi any help please
Clunk bang I am having a gear selector problem can move into gear at a push then have to switch off the engine fiddle with the linkages to get neutral the start the engine select gear but can't change gear stick is Floppy. Once I repeat the process to get neutral stick is behaving as normal. 2007 Grande punto active sport 1.4 8v manual box
Thanks in advance
Helsinki
Hi any help please
Thanks in advance
a floppy stick usually means one or two of the gear cables connected to the gear lever and gearbox are broken
quaffle
Active member
North Yorkshire
Check gear linkage cables.
You can see them on top of the gearbox and follow them under the car to the gear stick.
