Any ideas - shifter suddenly stuck in gear - I think in 2nd. Clutch engages and disconnects power from engine when depressed, but can't shift into any other gear; shifter just wont allow it - except reverse - I can select that, but it doesn't change the gear! I inspected the linkage - all looks ok from gearshift mechanism back to the "lollipop" rubber link to the main gear selector shaft. I tried disconnecting that and manually moving the shift selector shaft with a screwdriver inserted at 90 degrees into the shaft connector end, but I can only move it one way (I think to reverse) and it requires a lot of force just to do that. This happened suddenly about a mile from home, and I just drove it back home by standing on the clutch at intersections and stoplights to keep the car from moving. It drove normally in the one gear it was stuck in.
I suspect bad things are going on inside the gearbox with respect to the gear selector mechanism and expect to move ahead with pulling the drive train and probably swapping up to a synchro replacement gearbox. May even bite the bullet and do a full motor swap to a 650 126 motor. But interested in whether anyone with more experience thinks I may have missed something simple. I planned to do this upgrade anyway, but not until the car is off the road for the winter. Thanks!
