davestuart1973
- Joined
- Jul 5, 2009
- Messages
- 4
- Points
- 2
My stilo is a Stilo JTD Dynamic Estate and other then the brake lights it has given me no problems in the two years I have owned it, and if I can clear this fault I plan on keeping it a few years yet.
But, it has developed a strange fault, it first occurred after being serviced and I thought air was getting into the fuel, possibly not been done right, something loose etc, but i took it back to the garage and they checked everything and to be fair it stopped for a few months then re surfaced.
Its had the problem for about the last six months, as I rarely use the car and have just moved house so havnt got round to getting it fixed.
what the problem is, is that you can be driving along quite normally not driving hard or anything and as you are accelerating the car slows down as if you are braking. If you keep the same pressure on the pedal or put on more it just continues to slow down, but if you take your foot off and then accelerate again it goes off on its way as normal.
Sometimes it will do this evey minute or so and then it may not happen again for a few days then it may happen once or twice in half an hours driving.
It happens in all driving conditions really whether you are driving along normally or if you are are accelerating hard such as joing motorway etc so has me really stumped.
So far I've had suggestions that its air getting into the fuel and I should have it fully serviced all the filters changed and fuel system bled, and other suggestion was it was not the fuel but an exhaust or pressure fault which is stopping the exhaust gas getting out properly, blocked or faulty sensor or blocked coked up exhaust.
Anyone had the same fault or any more ideas, as just moved house so money is very tight and cant afford to put it in the garage for hours of fault finding
cheers
Dave
cheers
Dave
