General  Strange question needing an answer asap
rab10000
hello
just been on phone trying to get a rear radius arm/ rear trailing arm and was asked whether my ABS sensor is an 18mm or 10mm as they need to drill the hole, does anyone know if there a diference between the dieslel versions, ie does the 105 hp engine have 10mm hole while the 115 has 18mm?
dunno exactly where to look to find out, any help greatly appreciated
Didn't measure it before I threw them in the bin but as far as I can remember, the 105 sx diesel sensor is definately not 18mm:idea:. Its held in place with a 5 or 6mm bolt. Sorry can't be more definate but the ones I got just arrived, no questions asked about hole size.
hello
cheers for the reply its passenger side im replacing, when i look at the car where is the unit located on the arm?
i can find 2 bolts facing forward look about 6 mm or so but i cant find the abs unit
