strange brava problems,please help!
P
phillip robert
Hello,ive got a 96 brava s,and im getting some odd problems with it the the dealer(not a fiat one) cant figure out.First 2 of the cylinders were blocked and the other 2(?) were compensating for it,using way too much fuel,which also affected the timing.He fixed that but im still getting one problem.When i try to accelerate quickly(past about halfway down pedal to floor) I seem to lose all power!This is quite dangerous when overtaking so if anyone has any ideas please reply or email asap!Also the seatbelt light is coming on at odd times when im driving.
thanks !
Brava problem
Dear Pal,
I believe that your ignition coil is faulty. I had a similar problem but with 1 cylinder and the engine sounds like 1969 VW Beetle. Get it examined and replace the item if it is faulty.
Regards,
Gurjit
Malaysia.
thanks
thanks ill try that,along with some other things(lambda sensor,fuel ignition,ecu etc etc!)
I
2
1K
Dark Lurker
7K
David Slaney
P
3
880
paull
P
J
954
jason
J
G
2
908
T
