From memory:
Ecm battery (takes higher charge rate and more starting cycles)
Strengthened starter motor / ring gear
Sensor on gear box to detect neutral and reverse selection. Kill engine in neutral / disable s/s during reversing manoeuvres
Sensor on battery ( measures battery voltage / charge / power retention)
Sensors linked to engine temperature / blower heater / wipers / heated rear screen ( SS won't cut in till car is up to temperature, if windscreen demister or heated screen is on)
Brake servo pressure sensor (low pressure engine restarts)
