Right well i bought my 02 plate 1.2 stilo in late december. Since then there have been 3 major problems, 2 which still need sorting and 1 which I really need to drive
I suppose its best to start with the most important, when i bought the car it had just passed its mot on the fact the when you turned the key the first time it came up with the power steering not on and a message "loose connection" but if you turned the key back to off and then on again quickly it was fine.
This lasted untill recently when it just wouldnt start and so as to advice on here i changed my battery to one of my fathers ones, after that it was fine up until the other day when it went and just wouldn't come back on. Got it to an independant garage (spiros as recommended on here) where the friendly mechanic managed to tell me that after the tests all was fine and to see if it came back. Then today it did it again, I phoned him and he said hed want to see it again but changing the battery again may help. I am a bit confused here and want to know if anyones been through the same?
^ This problem if anyone has any knowledge of would be much appreciated as I really need the car to drive tommorow!
Second is both rear doors being deadlocked, i tried every trick on here in every thread over 100 times and then took it to a fiat garage to have it tested and they said both the rear door locks had failed and i would need new ones and a stupid labour cost. Have survived without the rear doors since january and now having the rear door locks as purchased from ebay i cant find anywhere to give me a labour quote of under £300/400!
Third was a engine misfiring but engine seemed to be fine when i replaced the pistons on the cylinders that it said were misfiring although i have noticed the ocational judder like it did before this happened last time.
have enclosed two pictures, one of the loose connection message and the two lights that come up when i turn the engine on and another of all the lights at just the engine power stage!
