MrF1
Has anyone out there done a ICE install on a Fiat Stilo 3dr 1.8 dynamic?
I'm looking to rig up a set of 6x9's on the rear shelf, install my 12" sub in the boot and replace the factory standard head unit with a new Kenwood lump.
First question I have is how can I remove the speaker grile off the speakers which are in the back seats on each side of the car? I was wanting to disconnect the speaker wire and extent to plug onto the 6x9's which I'll be installing on the back parcel shelf. Easiest option would be to run seperate from an amp in the boot but only have a two channel amp at the mo which is will be powering my sub bridged.
Second Question, Hasanyone remove the factory head unit yet, do I need special removal key's that are comonly used?
Last question, which is the best way to route the 12v cable from the car battery to the rear of the car? The sill's down the side of the seats is easy enough but where's the best place to thread the cable from the engine bay into the inside of the car?
Any help will be most appreciated
Stilo Dynamic 1.8 16v (Metalic Black, side skirts, rear spoiler and 17" wheels)
