Technical Stilo Abarth
terrence
Hi, Brought a Stilo Abarth couple of days ago with a damaged engine, replaced it with one from a breakers, installed starts up fines runs smove, But the car will not go in to gear? the salespeed fluid is a couple of mill above the bottom intake pipe could this be the reason it wont go in gear? any help wouldbe great
Terrence
can you hear sillyspeed pump pressure up when drivers door opened ?
yeah thats seems to be working fine, my salespeed res is low so mayb it's that making the gearbox faier light come on? also i changed the engine recently, do i need to bleedthe system?
i just spoke to a bloke, he said it wont need to be programmed, he said i should bleed the system and add the salespeed oil
