Sammyantha
- Joined
- Nov 6, 2013
- Messages
- 6
- Points
- 4
In need of some advice.
2004 Stilo 2.4 semi-auto selespeed. When stopping car/slowing down gearbox jumps down into N and gets stuck there, can't go into R or change gears. After a few minutes of turning car on and off and messing with gearstick it comes back and works ok again for a little while. Has happened 4 times in the last two days leaving us stuck at traffic lights and in car parks.
There are no gearbox warnings coming up but when local indi plugged it in he said a selespeed pump error showed and it needs a new pump. However upon opening door pump seems to prime fine for about 10 seconds. Will it defo be the pump? Also if it is, is there no way of getting a pump on it's own as it seems it must be bought with the actuator too?
Car has also stalled once or twice showing a quick low oil pressure error, not sure if this could be related or yet another problem?
We've only had it 4 weeks.
