Are you sure as that description seems a little odd to me :chin: Based on eLearn, the EGR vents exhaust flow to manifold PRE-turbo and as a consequence the turbo struggles to spin (as already described). You can't have the cart before the horse. Without a spinning turbo you wont have much manifold pressure to worry aboutNo. The EGR when open vents the inlet manifold to the exhaust pipe so the pressure created by the turbo is lost out the exhaust pipe. The turbo is still working normally.
Agreed - but is that not what I just saidThe rocker cover breather pipe enters the inlet just before the turbo and just after the MAF. It can not enter the high pressure pipes after the turbo.
If it's not worn then you have to account for the high accumulations of oil.No it wont be suffering from wear.
I thought this thread had already indicated a little oil is normal in this area - but surely that's not the same as saying large quantities are normal too.
...and if it is normal then WHY the big difference?
