Godzzi
I've just replaced my gearbox oil today and i'va come acrosse whit a dilema. I found 3 plugs on my gearbox.....
1. filler plug that is visible in the right side of the motor, below the intake tube. The size of the plug is 12mm allen key.
2. drain plug that is visible under the car. It is located on the left side of the gearbox and near the corner of the gearbox. the size is the same as filler 12mm.
3. ??? plug. It is visible only if you remove the left wheel and the left plastic shield. It is located on the left side of the gearbox and between the other 2 plugs ( in terms of height). the allen size of the plug is 10mm.
I've marked on the photo where is the unknow plug.
