Hi Fiat fans
Today I cleaned my idle control valve with carb cleaner and my map sensor with contact cleaner. It solved my most recent problem of rough reving between idle and 2000rpm, but my car is stil ideling too low
When cold idle is perfect and when hot it drops so much to near point where sometimes it almost stalls but recovers. low oil pressure warning intermidiate on and off as ideling drops.
Anyone who can solve problem plz help! I checked pipes for crack nothing. bleeded coolant system, spark plugs, oil, oil filter and spark plug leads are quite new.
Could it be oxygen sensors? problem is worsening to point where i get oil light everyday now then I have to rev to eliminate it.
Milage is 142000km and oil is shell helix plus 10w40
Anyone can point problem to oxygen sensor or water temp sensor? timing belt is fine as it was running perfect till recently
Thanks too all always willing to advice and spend time to help us amateurs
