Hello all,
My handbrake sticks on when I leave it on overnight or parked all day when I'm not at work. It started a few days ago and is progressively getting worse. Doesn't happen when in use on the road... It feels like it will cause a problem in the not too distant future but I have an idea of how to solve it, I wonder what you guys think....
What I'm going to do is pull the drums off and I expect to find a groove worn into the inside surface of the drum and that the pads are sticking in this groove... I'm then (if I'm right so far) going to grind the high points back to roughly flush with the worn braking surface... Obviously replacing everything would be ideal but if the drums aren't worn past their min thickness then why not....
Does this problem sound familiar and am I about to make a major mistake? As usual all feedback gratefully received...
Cheers, Luke
Cheers, Luke
