not really,though if you used a seperate amp it would cut down the heat.
if its really hot check there no hot air ducting come loose behind and is heating it up.
remember its warm weather now as well
well if oyu look under the dash/behind the stereo you will see plastic trunking that carrys hot air to the vents etc.if one was loose around the sereo you can get hot air surrounding the stereo area
