Hello to all,
After years of reading and learning from here, I decided to become a member of the forum. I have been doing easy repair and manteinance tasks for my fiat seicento, with the help of some of the forum posts, but now i have a bigger mechanical problem, and maybe it's time to give a step forward.
As the title says, it's a problem in the steering rack, one of the shafts have a lot of play (and i mean a lot, it makes a lot of noise when i drive in bumpy roads), and i didn't found any adjusting bolts, so i finally bought a new one. But there's the problem, when i went under the car, i found that even there are only two big bolts fixing the rack, one of them is barely accesible, and it's because some sort of support block and the gearbox is in the way. So, because it seems that there isn't room to remove the rack, I didn't continue...
I'm not sure about removing the gearbox, because i don't have proper tools (and not enough experience), so, it's possible to remove the rack without removing the gearbox? Maybe it's enough (and somewhat easy) to remove the support block to make room? And then, if possible, removing it from one side, after disconnecting the shafts...
Thanks in advance and sorry for the bad english
