AndrewRL
As always, I'm after a bit of advice. I've searched here but not found quite the answer and checked everything I can think of.
Luigi seems to be running really well (probably best ever) but is really difficult to start from cold.
To start takes at least 7 or 8 really long churns before any sign of "catching" and another couple before fully firing.
No issue with battery - kept on trickle as only get to go for a drive every couple of weeks. Spins engine over well.
Tappets, timing, points, plugs, fuel, pump all seem fine judging by how the engine runs when started and I've checked them all recently.
Any suggestions on where the problem may be and where you'd start?
Does this sound like issues with the starter motor? If so, can it be removed/replaced with engine in situ?
I'm hoping it is something fairly simple (and cheap!) but I am at a bit of a loss as to what is causing this.
Many thanks as always.
