Hi everyone
Been having a bit of an issue with the 1.2 16v recently, just over the past week or so it hasn't wanted to start. It turns over no worries but will only start to catch after having the starter motor going for a fair few seconds then it dies almost immediately after coming off the starter motor. If you pump the throttle hard or hold it on full throttle it will eventually start, then run rough for about 10 seconds not firing on all cylinders, after that it runs absolutely fine and will do all day long!
Also it stars fine if it's a hot start...
As I've said, no signs of any other issues apart from when it's starting.
Any ideas?
Any ideas?
