wickdogg
- Joined
- Jun 17, 2012
- Messages
- 9
- Points
- 29
Has anyone had a problem with rebuilt starters? I had one rebuilt and all it does is grind when I pull the starting lever. They told me the linkage may be too long and not fully extending the bendix into the flywheel. Well I disconnected the linkage up front and ran a screwdriver through the hole in the end of the linkage. I pulled the cable as far as I could and all I got was grinding again. Then to eliminate the cable situation all together I used the wooden end of a hammer to fully actuate the lever. The starter only made a grinding noise. I also tried to rock the car back and forth with the bendix fully extended and it did not mate with the flywheel. Any ideas? Shop possibly rebuild the starter incorrectly? I do have videos if anyone wants to assist. Thanks all for reading.
