Standard sized speakers in a bravo?
W
Will
Hi guys, just got a bravo a couple of weeks ago, was wondering what size speakers does the car take in the original mounts F+R?
And on another note, the rear wiper on it doesn't work at all, the wiper or spray, any ideas what the problem could be?
Nearly right. 5x7 in the front. 13cm in the rear.
Longest Serving BOO Member
Bravo: Nov 01 80SX / 70,000 miles
Coupe: Feb 97 20V N/A / 134,000 miles
Ok guys cheers, if i buy 2 5X7's and 2 13's then i'll be alright somehow eh :p
Cheers again
If you are going to fix the rear wash wipe you'll need to find the correct wiper motor for your car. They do seize if left unused and yours could be totally gone for all you know.
The best idea is a scrap yard but you can't guarantee it works until installed. You must make sure its from either Bravo/a's - the important thing is to get the correct variant. Mk1 or Mk2 since they have differnt connectors.
While you are installing the motor you can fix the wash feed.
The repair guide has step by step instructions for you.
Another question
Ive had a look around in the back and can only find one set of what look like speaker wires, ive checked behind the headunit and there are wires coming out of the block, just can't find em, should they be there?
Should be attached to your speakers :)
However, I'm guessing you dont have any there at the mo. Pull the carpet back on either side of the car. The wires may have dropped down there.
haha yeah, no speakers in there at the mo, it is an S so its gnna be basic!
Yeah the S doesn't have rear speakers, the wiring is there, its tucked away in the side walls and the ends will be covered up in a sticky sponge. If your using the original radio then the rear speakers wont work as its only 2 channel. Left and Right. If your using a different headunit, you'll be fine.
Items For Sale:
ePER V4.0 2008 DVD, Fiat Bravo/a Passenger Airbag Covers to suit MK2, **MINT** Fiat Marea Poly Elliptical Headlamps with Sidelight Connectors, Bravo & Marea Workshop Manuals, Fiat Bravo Haynes Manual &, Fiat Bravo Owners Manual on CD etc...
[email protected]?subject=FiatBoo Enquiry">Contact Me for more details.
Hi guys i checked in the boot behind all the panels, but couldn't for the life of me find the wires on O/S, found em (i think) on N/S they are red and blue and white and red. where should the wires be on the R/H side?
M
1
728
Dark Lurker
M
7K
M
A
1
11K
Angelo
A
