General Squeaking from back.
Midlands
Hello, I have an annoying constant squeaking from the back. Seems pretty constant, more so over rough roads, but not always. I'm thinking it might be the rubber seal against the boot. I have rubbed a little oil on it hoping that would help but no luck.
Anyone else experienced this or any idea what it could be.
Cheers, Phi
I found that not only the boot seal, but also the door seals squeek a bit. I used a silicon based lubricant, spray it on a kitchen towel then rub that on the seals as well as the contact area on the door itself. I found that it solves the problem till the next wash.
Also check the rear window seals and make sure the window hinge bolts are nice and tight.
Make sure of the spare wheel pressure and that it is raised properly - if it looses air it might maybe squeek against the body.
