I'm new to all this, so need some help.
Guns - I have a suction feed spray gun. 1l pot but the pipe inside doesnt reach the bottom. problem? I wont be doing whole cars, more liekly to be the odd panel or so. Would a gravity fed gun be best? I guess both have their ups and downs.
I only have a 24l 8bar compressor, so I presume some guns will require to much pressure.
Paints - Seen this mentioned in a few other threads.
I understand that cellulose mixed paints are fading out due to it being bad for enviroment, and 2K being dangerous unless you dont have the right breathing equipment.
Waterbased seems a good sensible option, but can you use 1K primer and laquer? take it 1K isn't as bad as 2K?
Mixing - How do you know how to mix the right amount, buggered if you do to little and wasting if you mix to much. Is there a calcualtion for working out paint volume to surface area of piece being painted?
Perhaps someone could do a guide on this. Be useful for many I expect.
