Technical Spot lights not working
Daver
Staffs
Can someone tell me where the earthing point for the front spotlights is please, I have read the other threads about similar probs and my Garage have tested and power is getting to all the places it should be, but no lights?.:confused:
simple way of testing the ground on both lamps pull the multi plug off the back of the lamps
shove a multimeter probe in the both holes (terminals) and turn lights on.... if sound you will get 12 v (ish)
next if no results stick your probe on a clean bolt on the chassis or even on the -ative terminal and see what happens (you might need to swap to the other hole on the multiplug) or you could do a continuity test
do it both ways (ie test the earth at the plug to battery live) to prove out a live supply fault)
sounds really silly but have you tried a new bulb?
If you are 100% sure your bulbs are ok ,and that you are getting a positive feed .Just for a quick test ,to confirm your suspicions of a faulty earth , run a wire from batt neg ..If bulb lights then trace back to you find and fault
What i wil add about the use of a multimeter,is be careful ,as they can lead you astray .Though it may show 12Volts ,it isn't drawing any current ,it is just battery voltage ,putting a test lamp over the plug would draw current ...Was told that many many years ago as an apprentice when i thought everything was ok on a training aid ,to be told i was only reading batt voltage
I have one spotlight not working at the mo, going to have a look at it now to see if its a bad earth.(n)
