Technical Spider starting problem
koosfan
I have a 1981 fiat spider. Fuel injection.
It was in storage for two years------but started
right up. It ran great for a week or so and
then failed to start.
The fuel filter was clogged-----gas tank was
a little rusty. Tank was cleaned, new
filter was installed.
but it still won't start-----ideas? suggestions?
I have the same problem. I just got my 82 Spider. The P.O. had it running last week, but now it won't start. Runs on starter fluid (ether), but not without.
GW
You guys need to get a Fuel Injection Diagnosis manual (available from several vendors). Both sound like fuel delivery problems: fuel pump, bad/stuck/clogged injectors etc.
Thanks George. I found this...
angelfire dot com/wa2/fits/index.html#ljetguide
I'll see if that does the trick.
GW
Got my fuel pump out today and it is messed up... Couldn't pump a river down a mountain. OEM replacement or Carter?
