IndianaAndrew
- Joined
- Aug 13, 2012
- Messages
- 15
- Points
- 58
I posted this to both Xwebforums and here. True Fiat diehards might see it in both.
"Indiana"Andrew is now "Michigan"Andrew. I don't think the site allows me to change usernames.
I am working on my childhood car, a Bottle Green 1971 124 Spider with the 1608 engine, purchased at age 14. I drove it through most of my high school, graduating in 2011. It hasnt ran since then really. I purchased a carb kit for the original 28/36 DHSA and one of our vendors called up saying he really dislikes selling kits for that carb and provided a chinese knockoff weber of the recommended model for this car. The original was looking pretty sad. That was a year ago and i forget the "weber" model. I also have a single plane intake. Engine fired up with new carb to find out i was running on 2 and 2x 1/2 cylinders (head gasket failure in 1, bad spark plug threads in 4).
The engine is going through a full rebuild, everything removed. I painted the block Detroit Diesel Green. Well this weekend I tried honing the cylinders. Cyl 4 has some marring maybe from rust midway down. All cylinders have a visible ridge at the top that was considerably more than I could clean up honing, and very tactile. piston to cylinder clearance is greater than acceptable range. Pistons, class A, do look really good with minimal wear. Cylinder 4's pitting/marring/rust was probably from the spark plug threads being messed up. That's since been drilled out, tapped, and a solid insert installed. Valves should be stock. I had intended to run it as is even after the hone. Then rebuild later after seeing how this car is suppose to behave and feel.
It looks like i need to get it properly bored. I measured bores at the ridge and at the largest diameter. The max OD I measured was 80.096 mm. The ridge delta looks to be about 0.0030 inches = 0.0762 mm.
- What do you all recommend for pistons?
- I need to get my flywheel resurfaced; it's got a nice layer of surface rust. Are there any lightening suggestions or no one has a trusted design beyond one off the shelf. I read there's a 16 and a 19 lb flywheel. How to tell the difference beyond weight? My only scale is doesn't reach that high. New clutch already purchased.
- Any other go fast goodies while I'm here? It doesn't look like I'll have the A to B comparison, stock to built.
- Rust issues: Shock towers, left jack point, engine bay battery box, wheel well at front left anti-roll bar mount, left "frame rail" where it curls up at engine bay. Floor pans were redone but could be better. These I will improve over time.
- Hard brake lines show rust. intending to replace while engine is out. I'm looking for a roll of tube at proper size.
- Rear axle pinion seal, check condition of diff and Bevel Gear Set.
- All bushings and ball joints purchased to redo full front suspension.
- Model
- Fiat 124 Spider 1608cc
- Year
- 1971
