Technical  Speedometer Issue
Medicine Hat, Alberta
Need some guidance, removed my instrument panel and changed to LED lamps. I put the panel back in and now my speedometer doesn't work. The odometer is working fine. I removed the instrument panel again and used a drill to see if the speedometer would work and it does, I watched the speedometer cable while I had the car blocked up and it works. Put it all back together again and speedometer does not work but odometer does. HELP!
