speed
  • Thread starter whitey
  • Start date
  • Replies 2
  • Views 313
speed
W
whitey
I have just fitted some 17in alloys to my bravo, will the Speedo now be off and if so what sort of difference will it be.
Tyres
What tyre ratio are you running on your 17's...If its 205..40..17 you will be fine.
40..17 being the most important part, thats diameter and tyre wall height!
tyres
205 is also important because, the 40 means 40 % of the width of the tyre which in this case is 205. If you fit 225 size tyres then 40% of that will give you a different tyre wall height and therefore change the rolling circumference.
worth bearing in mind
E
1K
E
T
492
T
K
8
821
K
C
18
2K
Anonymous
A
C
614
Christopher Miller
C
